DataMaster "Fuel Air Value" or O2 mV??
Old Jul 3, 2002 | 04:25 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
I've been reading alot of posts during the tuning of my prom, and somewhere I read that the "perfect" air/fuel ratio would have a .450 mV reading, now from that I would think that would mean from the O2 sensor volts. But I see there is a field on my DataMaster scan tool called "Fuel Air Value", and it sits usually around 440-470, does say mV or any units value, is this what alot of posts are referring to when the .450 is mentioned because from the O2's perspective I would have thought the around .750-.800 mV would be desirable.
Old Jul 3, 2002 | 04:51 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
This question (stock O2 sensor) is so frequently asked, it should be an FAQ.....
Don't use the stock O2 sensor for tuning. It is designed to run 14.7:1 (stoich) as a switching device around .450 volts. It was never intended (nor should it be relied upon) as a tuning aid. It rapidly becomes inaccurate above .75 and below .25 Volts. And the closer you come to 0 or 1.0 volts the more inaccurate it is.
If you want to tune for WOT, get a WB O2, do plug cuts and performance measurements (1/4 mile being the best).
Old Jul 4, 2002 | 11:10 AM
2QUIK6's Avatar
Well I'm not really looking at it from a WOT perspective currently but will be soon, but while on the subject of the WB O2, are they a direct replacement to the 3-wire heated sensor for a '92 TPI? Did the f-bodies originally have a 3-wire or single wire O2? This is on my truck that was originally converted from TBI to TPI is why I ask and it had a 3-wire heated O2 thats in use now.
Is the "Fuel-Air Value" field in DataMaster what I should be paying attention to?
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
