BLM cell numbers and boundary ?
Old Jul 5, 2002 | 10:23 AM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
How are the BLM cells numbered? If there are 16 cells, why do the boundary parms only allow 3 values per axis, that would only be 9 cells unless 0 is assumed on both, but I would think your idle speed should be the lowest on the RPM axis?
If my KPa boundary is 25, 50, 80
And my RPMs are 700, 1200, 2000
How would the cell# correlate in the table below?
.........25 50 80KPa
700 . | ?. ?. ?.
1200 | ?. ?. ?.
2000 | ?. ?. ?.
Or if 0 is the default low value for each...my guess is they are numbered as follows:
.......... 0 25 50 80KPa
0..... | 0. 1. 2. 3
700.. | 4. 5. 6. 7
1200 | 8. 9. 10 11
2000 | 12 13 14 15
Is that right?
Old Jul 5, 2002 | 12:27 PM
Chevero's Avatar
I have an 730/8D, and the BLM array is close your second choice:
kPA ....|................................RPM
................0-850...... 850-1600.....1600-2400......>2400
>75............12.................13..................14...............15
50-75...........8...................9..................10...............11
25-50...........4...................5....................6.................7
0-25.............0...................1....................2.................3
As you can see, the cell# advances through an RPM range before
moving up to the next kPA level. My 730 idles in cell 4, at 725 RPM and about 35kPA.
Hope this helps you--
Old Jul 6, 2002 | 07:25 PM
92zeddar's Avatar
my BLM cell MAP boundries are
low.............25
med............50
high............75
Cell RPM's are
low...........1000
med..........1600
high..........2400
and that is for a 730 ECM $8D why are mine so different? and how be these be numbered??
Old Jul 6, 2002 | 07:50 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
That's coincidental. Cell 4 is the "idle" cell by default. You can change those MAP/RPM boundaries till your blue in the face, it will still idle in Cell 4.
This is because there is actually a "variable" that you can select the Idle BLM cell to be on the 7730. By default, it is Cell 4.
Old Jul 6, 2002 | 09:01 PM
Chevero's Avatar
low.............25
med............50
high............75
Cell RPM's are
low...........1000
med..........1600
high..........2400
Actually, Glenn91 said it: The cell boundries can be changed (or originally different from GM), but the "Idle" cell seems to always be 4. Your cells are identical to mine except for the lower RPM, where mine is 850, while yours is 1000 RPM. A minor change in the code.
The cell #s would be similar to mine, i.e., 0 is 0-25kPA& 0-1000 RPM, 1 is 0-25kPA & 1000-1600RPM, and so forth.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
