Scanner or laptop?
Old Jul 10, 2002 | 12:56 PM
87transam5.7tpi's Avatar
Scanner or laptop?
first off what is better to use to gather info? laptop or a scanner?
also I went out today witha scanner and got some interesting info. the max my TPS voltage would go to is 4.34v which from what I read is right. but it wouldn't go into "open" loop. I also have my tranny kickdown cable all the way out to get to that 4.34v any other way and it wouldn't get above 4v. what do I need to adjust to get my engine to go into PE? thanks
Old Jul 10, 2002 | 02:37 PM
IROCZ88's Avatar
A laptop is better cause you can gather and store everything on spreadsheets.
The tech articles section has some good info on adjusting TPS, IAC, TV cable, etc...
Old Jul 10, 2002 | 03:10 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
The ECM goes into PE mode based on a percent change in TPS voltage, not necessarily going above a certain TPS voltage level.
To change this requires going into the PE tables and changing things there.
Old Jul 10, 2002 | 11:52 PM
ya I know how to adjust all of that and I did. it just doesn't seem like its running right (like I said above) what you you guys have your PE % set at? Just curious, thanks once again
Old Jul 11, 2002 | 01:13 PM
2QUIK6's Avatar
My PE setting are still the original settings at:
400rpm - 50% TPS
1200rpm - 50% TPS
2000rpm - 50% TPS
3200rpm - 60.2 % TPS
4800rpm - 70.3% TPS
Maybe I confused you with my wording in the previous post, but it is a % of TPS at a certain rpm that enables PE mode.
Old Jul 12, 2002 | 10:40 AM
so if my TPS voltage is at 4.34 and it doesn't kick into PE what is my problem? could it be the TPS? like going down the highway at 65 (2000rpm) and then putting it to the floor(4.34v) it downshifts but doesn't go into PE(open loop) thanks
Old Jul 12, 2002 | 01:59 PM
2QUIK6's Avatar
Well if the ECM is seeing 4.34v from the TPS, that is enough to put it into PE mode, provided the '87 TPI is programmed similar to my '92 TPI, I believe yours is a MAF instead of SD, but it should work the same I'd think. Sometimes they can be picky and its usually recommended that the TPS voltage be above 4.5v at WOT, you may want to adjust the TPS sensor so that it sees > 4.5 at WOT by loosening the bottom screw and kicking the bottom part out toward the front while the top remains in the current position.
If you can;t get 4.5v, then you may want to try another TPS sensor. Don;t know what else would keep it from going into PE if thats not it.
Anybody else have any ideas?
whtltng89
Sep 8, 2015 07:06 PM
CORV3TT3
Aug 23, 2015 11:26 AM
Electro_X
Aug 19, 2015 07:59 AM
mizz0313
Aug 12, 2015 06:45 AM
bowtie1983ss
Dec 4, 2001 12:18 AM
