30Lbs/58MM idle off the wall?
Subscribe
Aug 5, 2002 | 10:14 PM
Hey Guys,
If I throw a set of 30lbs injectors, and a 58MM throttle body into my mix (see sig) you think:
1) My idle will be dead
2) I'll run too rich when the vortech FMU max's the rail pressure?
I'm curious if this would be an ok move, or if intense programming
would be required to get it done.
-- Joe
Reply 0
Aug 5, 2002 | 10:27 PM
not entense programming jus a simple one second inj constant change.The chips are matched to the injectors.Ford ecms are matched to the maf.So injector changes for a ford does'nt require recal.
Reply 0
Aug 5, 2002 | 10:30 PM
So, you think otherwise they would workout? Or would I be better off with the 24#?
Thanks.
Reply 0
Aug 5, 2002 | 11:16 PM
better to have to much fuel than not enough.
Reply 0
Subscribe
