Fried?
Old Sep 8, 2002 | 01:01 PM
James Montigny's Avatar
Fried?
If the Prom is inserted backwards, and the key turned to ACC (not started) will the prom be fried?
Old Sep 8, 2002 | 05:24 PM
Morley's Avatar
Doubtful. Try it in the right direction?
Old Sep 8, 2002 | 06:18 PM
If I put the prom in with the notch (Pin1 ?) facing the notch on the carrier and the large (1) . I get a Check Engine light that flashes rapidly. I noticed this when I first installed it, and assumed that meant it was upside down. (I have a feeling I was mistaken)
If I flip it around, I get a solid Check engine light. Both throwing
a Code 51.
My car is running like a 4cyl right now, no ***** at all. I assume it is in "limp-home mode" (Excuse my newbieness - most of my experience is with 4th gens)
The worst part is, I screwed around with it whiel troubleshooting
so much that I have probably messed up both my original chip
and my new one. (It was hot as hell out there today, my poor Canadian body will never adapt to Kansas weather)
Oh well .. back to the drawing board
Unless anyone can think of something else.
Oh . FWIW -
I read in my Haynes manual that installing it backwards can fry the circuitry in the prom if the car is started. Solution: Replace prom (DOH!) - I had to start the car to get home.
- James
Old Sep 8, 2002 | 06:36 PM
Morley's Avatar
If it is a flash prom you might be ok. Try to reprogram it and put it in and try it. The manual would say to replace it because they don't take into account that people would be programming their own chips.
Old Sep 8, 2002 | 06:44 PM
okie dokie
BRoss99
Aug 10, 2025 05:08 PM
RedLeader289
May 28, 2019 01:47 PM
chazman
Aug 28, 2018 03:25 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
chazman
Aug 22, 2015 02:01 PM
