AE, EGR, and Camshaft specs
Ladies and Fellas,
I have been experiencing a very significant lean condition when I tip the throttle in. I have tried to adjust the AE tables in order to correct it but with no luck. I am using a Crane Cam 214/220 .452/.465 112 LSA cam and I am using the ARAP as my base for tuning. I have a question regarding the EGR function, I know that an EGR valve that is stuck open (too much exhaust gas being introduced back into the intake tract) will cause a car to run pretty lean and also cause the car to misfire, but with this camshaft I am using does it have as I have heard "Self-EGR" characteristics so much so that I can turn it (the EGR function) off in the PROM altogether?? I have a suspicion that it is not helping my lean throttle tip in.
Thanks,
Brian P
89 IROC-Z 355
Thanks,
Brian P
89 IROC-Z 355
First be sure you idle air control motor is functioning properly
and adjusted correctly,normally counts between 5-30 at idle
are good.
If that is good and blms are good at idle and AE make little difference then maybe try lowering minimum delta tps% to enable acceleration enrichment.
I would also lose the EGR unless you are concerced about emissions .
are good.
