HC's too high, but blms and int very lean
Old Sep 12, 2002 | 05:50 PM
1987gta's Avatar
Ive been trying to get my car to pass emissions, at least idle the test because a friend works at a garage. Moates software says that the engine is running super lean (what I burned for in the chip), but the thing is maxxing at 2000 HC's. The car runs great, but is a little stinky when at idle. Funny thing is that the plugs all look great. Im still using the 165 ecm and think that it might be taking a dump (small unusual probs), so the next step is to convert to 730. Id hate to put my small amount of money on something that will not have an effect though. Can anyone think of a good reason for my problem. Look in my sig to see the stuff done to car. I also have new heated o2 (although its bosch brand), new plugs, wires, cap, msd module, etc..., and its basically a new engine with a little over 2k on it. I had a problem with oil as the springs took a dump a few months back. I replaced all seals and put nicer springs on. Fp was also set low when tested. I know the cat has been through a lot in the past 4 years (Random cat) because the 305 had seal probs since the cat was new. Do you think the cat would have a huge impact, or maybe a combo of that and something else? I would really appreciate any tips, or suggestions.
Thanks,
Joe
Old Sep 13, 2002 | 08:03 AM
32V_DOHC's Avatar
You have a lean misfire. Add some fuel back in and the idle should clean up, smell better, and the HC's will go down.
HTH
John
Old Sep 14, 2002 | 01:15 AM
1987gta's Avatar
cant believe I didnt realize somthing so simple. Im kicking myself for that one. Im going to try a few more burns tomorrow to see if I cant fix this problem, aqnd get it ready for another go on the emissions machine. Thanks a lot
Joe
Mark_ZZ3
May 24, 2018 01:02 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
sammy52401
Nov 11, 2015 07:20 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
