8746, EGR, and TunerCat
Old Sep 14, 2002 | 02:20 PM
MILT's Avatar
I've searched the board and cannot find an answer as to how to turn off the EGR on TBI PROM. TunerCat has EGR on/off constants for Low MAP threshold, speed, and % TPS. I've read that one member tried disabling EGR via raising the EGR "on" speed to max value, but it still came on at certain times. Is there a better way to turn it off, or should I simply raise all three "on" constant values to their respective max levels?
Thanks for any info,
MILT
Old Sep 14, 2002 | 04:29 PM
32V_DOHC's Avatar
Raise EGR enable temp to FD(253)
HTH
John
Old Sep 14, 2002 | 10:41 PM
JPrevost's Avatar
Car: 91 Red Sled
Turn the EGR enable temp all the way down as far as possible. This constant is an inverse, don't raise the temp, you'll notice that it'll still come on. If you don't have the EGR enable temp in your software you should ask TunerCat through e-mail to add it for you.
Old Sep 15, 2002 | 07:47 PM
32V_DOHC's Avatar
Amazing what kind of feet your mouth collects when you do not look before you answer. My bad
Jon, You are right the constant is inverse. Lower the constant all the way down. If they give it to you in degrees (constant run through a formula temp = 103.75 - (constant *5/12)) you will need to raise the temp to 103.75(this should lower the constant to 0).
HTH
John
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
ULTM8Z
Oct 2, 2015 01:25 PM
