Newbie ALDL cable questions...
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
http://w1.601.telia.com/~u60113744/s.../aldlcable.htm
OK, check this out... I've got the parts for diagram #2. I'm gonna build it like... right now, as I'm typing this. Anyway, I don't understand R3 in that... do I need to wire a resistor between there?
Also, will 1/4 watt resistors work here? 10k ohm... I've got tons of them. How do I figure out how much wattage I need them to handle in this?
PS - I'm a computer geek. I know PCs, and Cars. I'm learning electronics, so go easy on me, as I learn, ok?
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
some ecms require a resistor across those pins to enable aldl mode. just keep one handy and plug it into the aldl port per the diagrams when you are using it. 1/4W are fine. the current is really minimal. cheers, Bob
OK, new question... does it matter which way I solder the resister into wiring?
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
