my friend and I are getting ready to buy some chip burning appearal. we need the things to work for a 91 rs, 93 camaro and a 95 truck, so basically all the OB1 computers
any help? I'm basically lost
ok epromer programmer cheap
www.ustr.net looking for the epromer5 ( or look on ebay )
for software goto www.tunercat.com
the software is 69.99 i believe and youll need 3 def files.
is that 95 truck really obd1 ?? some werent if late in the production year.
for a scanner cable check with
www.akmcables.com
for software for the camaro check www.moates.net
if you need a scanner for the $95 pickup i think it depends on weather its a manual or autmotic.if its a manual it could have a 1227747 which would mean the this link would work
www.winaldl.webhop.net
as for the camaro again is it an lt1 or a tpi ? model year splits there from 3rd to fourth gen its a 93 with a 1227730 ecm youll need the tunercat $8d tdf
for the pickup if its got a 1227747 you need $42 ( comes with sofwtare as a trail thing )
for the camaro rs youl l need $88 its a v6 3.1 right ??
this is all i can think of
if you need more scannign power check out www.easediagnostics.com
they make some inexspesive scaner packages for private owenrs at reasonable prices and i do belive the akm cables interface works with it. ok man get some specific find out what ecms you have we will be glad to help.
www.akmcables.com
thanks for the help
my camaro is a 305, the truck is an auto, aren't the scanners just code readers? I can do that with a paper clip so I won't want to waste the money on those.
