Possible Touchscreen 1.5 din option?
Old Oct 1, 2015 | 03:35 PM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
Hey All,
So I have been doing a lot of research on what I plan to do for the radio setup in my 84. I see that there are a lot of options out there, but it mostly comes down to modifying the trim piece or not, the trim piece is obviously set up for a 1.5 din unit (which there isn't very much aftermarket sources for this), so you either need a 1 or 1.5 din unit or modify the trim piece to fit a double din unit.
my plan was to modify my bezel and do a double din unit, my thought was to find a reasonably cheap android powered double din unit to install in my dash, but while digging around on the internet I started finding there was a lot of resources for these android units, custom fit to specific car applications and what not. obviously the thirdgen fbodys where not in that list.. but other vehicles that use a 1.5 din unit where.. which peaked my interest.
so it looks like there are a couple pretty common newer vehicles out there that still come with 1.5 din stereos stock (jeeps/rams/chrysler 300's/etc). so I cam across a unit on amazon that looks promising for a decent price. its made by a company called pumpkin, which seems to just be a company that takes these chinese android radios and slaps their label on it, I have seen the same radio listed on ebay with a different name too. from the research I have done and videos I have watched, for the most part.. these are pretty solid units for the price.
now I don't know for sure if this will fit 100% or not without pulling the trigger and buying one (which I was planning on doing at some point), but I am pretty positive it would be a close fit with minimal work involved. now if you look at the pics it shows "measurements" of the unit, but I wouldn't take them too serious, this says double din, but doesn't appear to actually be that, and the measurements are obviously wrong, because in the pic it shows the total height as 96mm, but then flips around to the back and shows the smaller part as 100mm (100mm is height of double din), from looking around, people who have bought these and similar units (rebranded) have said they are a direct fit.
So here is what I found:
Pumpkin CS-W1702B 6.2 Pumpkin CS-W1702B 6.2" Unit for a Jeep Wrangler
Old Oct 1, 2015 | 09:47 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Possible Touchscreen 1.5 din option?
I would be interested to see how it works out. I really don't want to have to modify my original bezel if I don't have to.
Old Oct 2, 2015 | 06:54 AM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
That's a lot of cheese to spend on something they can't even measure properly........
Old Oct 2, 2015 | 10:38 AM
hectre13's Avatar
Engine: HO 5.0
That's exactly what I was thinking, if I can get ahold of an aftermarket unit that will work without modifying (too much) that would be perfect.
yea, these Chinese companies don't care a ton about the small details and mostly are just trying to sell as much as they can with as little effort as possible, I think what I am going to do is try and see if I can get ahold of a wrangler head unit and compare the size of it first, I should be able to get a better idea of the size that way. I'll keep this post informed on my findings.
Old Oct 2, 2015 | 12:19 PM
hectre13's Avatar
Engine: HO 5.0
a little more research confirms that they are a direct fit into the JK series of jeeps, and from what I have been reading is that those jeeps are in fact a 1.5 din unit, but I still want to get actual measurements to know for sure before ordering.
on a side note, there is a jeep company called "Insane Jeep Audio" that rebrands these things and sells them as a direct replacement to the JK series of jeeps, they sell through third party dealers, the model number through them is called the JK1001, and they have a price tag of $1100+ haha! wow, what a markup from the pumpkin version (without a bunch of hacks to the android operating system)
http://www.4wheelparts.com/Interior-...pn=I%2FEJK1001
here is a video of someone actually using one in their jeep.
Old Oct 2, 2015 | 08:20 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
I've also been checking out the few supposed 1.5 DIN radios still in use today, all of which do seem to be for Jeep. And the pic you posted in your first post appears to show the unit in its actual size(on my computer screen), or at least, proportionately accurate. So I held a 3rdgen GM radio that I have in my cupboard up to your pic on my computer screen, face-to-face, and the height and width matched almost perfectly. And it's obvious that the proportions in the pic are true to the radio because the ***** are perfect circles, not elongated as if the pic was stretched in either direction.
Just be sure the one you get has face lettering that is illuminated in red, or is at least is changeable, because a lot of the Jeep units I've seen only have green illumination.
I installed a double din DVD/CD/Bluetooth/streaming radio into my 06 truck a couple of years ago, and it was very nice, especially when I drove from CA to FL last spring. Watching movies while I drove was a nice change from only having music. And because the movie seemed to be over almost as soon as it began, 2 hours seemed to pass by quickly. Just be sure to directly ground the wire that's supposed to tap into the parking brake, rather than actually tapping it into the parking brake(that's the safety feature to prevent people from watching movies while they drive; it's just a ground wire). I put a switch between the unit and the grounding location, so when I wanted to watch a movie, I'd just flip the switch, the unit was grounded, and it was show time.
It was because of this install that I began searching for something similar for my Formula, but like you, something that fit "correctly" and looked appropriate, daytime and nighttime. And the Jeep units appear to fit the bill, if they have variable illumination, and some do.
What the heck, it's only cheese, right? And a similarly featured double din Pioneer, Kenwood or Alpine requires just as much, if not more, cheese to acquire than these Jeep units.
Old Oct 2, 2015 | 09:58 PM
hectre13's Avatar
Engine: HO 5.0
I do believe that the colors are adjustable, so shouldn't be any worries there. I have someone who has a jeep that I am going to measure their unit to verify, hopefully I can get some input on this tomorrow.
Old Oct 29, 2015 | 10:07 PM
mars2878's Avatar
Car: 14 Charger RT rwd dd
Engine: 5.7L Hemi
Transmission: auto
any updates?
Old Nov 9, 2015 | 06:20 PM
AmorgetRS's Avatar
Very interested in this...
Old Nov 12, 2015 | 02:00 PM
84ws689bird's Avatar
Car: 1988 IROC
Engine: 5.7
Axle/Gears: 2.77 posi
I'd be the buzz killer here.. Some Chrysler /Jeep products did come with a double din radio and had a corresponding Radio bezel that had a 2 din opening. a common solution to jeeps, etc. without the 2 din is to buy the dash bezel from dodge, etc. and replace it with the 2din bezel, allowing a double din to fit. As far as I can tell, this looks to me like a double din unit designed to replace the factory 2 din unit.
Old Nov 12, 2015 | 02:49 PM
hectre13's Avatar
Engine: HO 5.0
Hey All, sorry for the late response.. I still haven't had a chance to get any measurements or consistent info on anything.
It IS true the some Chrysler / Jeep units came with a double din radio, but this unit from pictures and videos doesn't look as tall as a double din unit, it seems to be closer to a 1.5 din unit, which is what caught my attention.. I originally got started looking for stuff because people who own chrysler 300's were trying to find a replacement unit for their 1.5 head units and after digging and digging I came across this one, which appears to be what I was looking for, but I can't 100% confirm..
here are examples of 2 units sold by the same company.. the one above.. and their double din unit.. and you tell me what you think.
Double Din
Jeep Unit
The double din photo looks a little taller than the jeep unit, but I could be wrong and the photos could be off.. but the jeep unit in all photos and pics look shorter than the other double dins.
Old Nov 12, 2015 | 03:10 PM
AmorgetRS's Avatar
Hectre - have you tried asking the guy who did the YouTube review to measure the face of it? I only ask because I wouldn't want to bug him about it if you already did. I would think face place measurements would put this to rest rather quickly.
Old Nov 12, 2015 | 03:18 PM
hectre13's Avatar
Engine: HO 5.0
I have not.. didn't even think about that. I'll send him a message and see what he says, thanks!
Old Nov 14, 2015 | 09:59 PM
Wife'sCar's Avatar
Engine: 5.0 Tbi
https://www.amazon.com/dp/B00UH4GZQM..._TkaswbTPP8J9Y
Possible solution? Fits in single din, but has a larger faceplate.
Old Dec 25, 2015 | 12:41 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Any progress with this? Also does anyone know if they would work with steering wheel controls?
Old May 19, 2016 | 08:42 AM
matt smash's Avatar
Car: 1987 Camaro Iroc-z
Engine: 383
It appears this thread has become dormant
Old May 19, 2016 | 02:00 PM
hardon85's Avatar
Just a little extra info here. the switch that needs to tap into your parking brake (from my understanding) can not be constantly grounded. I guess the aftermarket folks caught on that people were just grounding these wires, so my understanding is that once the unit is turned on it needs have no signal and then a grounding signal. I never hooked this up in mine but I read it multiple places. If I remember correctly there was someone who would sell something that once it got power (turned the car on) it would break the ground signal and then ground it again so it would all work automatically. However many people just install a switch just like you did.
Old May 19, 2016 | 06:38 PM
FirebirdUSX's Avatar
Car: Firebird
Engine: 5737cc
Chrysler 300M has a stock 1.5 din navigation/radio unit.I had to buy a Chrysler to discover that.
Old May 19, 2016 | 10:21 PM
echo-delta's Avatar
Yes it will fit look on amazon 2008 jeep wrangler direct fit radios found pic of one with mounting holes on the sides and showed three holes for screws one din placement and half way up another hole for screw bam 1.5 din .Those factory holes are set up for din size no matter where in the world it's made
Old May 19, 2016 | 10:24 PM
echo-delta's Avatar
And showed information for Chrysler car also which supports my opinion it is 1.5 din
Old May 19, 2016 | 10:26 PM
echo-delta's Avatar
Also look at first pic in post look at mounting holes
Old Dec 1, 2016 | 07:46 PM
Tims86's Avatar
They sell aftermarket bezels to fit a double din.have done a few if that is an option for you.
Old Jan 29, 2017 | 11:44 PM
LAFireboyd's Avatar
Let's breath some new life into this thread.
Not only Jeep radios, but also Toyota radios have wider-than-Double-DIN faces, doubling our candidates for modern, aftermarket replacements. They're even wider than the face of our 1.5 DIN radios, while having "bodies" of Double DIN radios(though some have the bodies of Single DIN). All of that is good. So rather than requiring a Double DIN faceplate to be manufactured(which, unfortunately, won't match the finish of a Firebird's factory faceplate), or "patching" the gaps in a factory faceplate for use with a Double DIN radio, the opening of the factory faceplate can simply be enlarged for a "custom-fit" with an aftermarket radio made for Jeep or Toyota.
More specifically, the faces of aftermarket radios for Jeep(as posted above by the OP) and Toyota are approximately 8" wide. The opening in our factory faceplate is approximately 7.5" wide(the face of a Double DIN radio is only 7" wide). So cut-and-widen the opening of the factory faceplate for use with Jeep or Toyota radios.
Also, the face of those radios is approximately 4" tall, which is true Double DIN, whereas, our 1.5 DIN radio face is approximately 3-3/8" tall. So here, too, cut the opening of the factory faceplate to match the taller height of the new radio, just as you would have to do anyway for a Double DIN installation.
Next, use plastic polish on the factory faceplate's freshly-cut edges(and face), and you'll have a newly-refreshed factory faceplate that fits the new aftermarket radio perfectly, making for a "factory-like" installation of a modern radio.
Now the issue becomes depth: making the new radio, itself, "fit" into the car. The aftermarket radios are slightly deeper than our factory radios. But you would have this issue with a Double DIN installation anyway.
The wire that's supposed to get tapped into the parking brake is simply a ground wire, so it can be grounded anywhere. I had installed a switch for grounding and interruption, located between the unit and the grounding point(not the brake). Switch on, the unit is grounded, and videos play while driving/anytime; switch off, the unit is not grounded, and videos won't play at all. I did test it without a switch, grounded 100% of the time, and it worked fine too. But I had previously "heard" the same info that you stated above, and that's why I installed the switch, just in case...
Old Feb 28, 2017 | 07:15 PM
SuperRamFormula's Avatar
Car: 87 Formula 350,11.65@122
Engine: 383,AFR Comp 195,XFI280,SRam/Mram
Transmission: T-56 Magnum-F
Axle/Gears: DANA 44 with 3.92
Ceramic coating makes a huge difference in the heat the headers produce. My first set of SS headers were SLP 4 into 1 shorty's uncoated. The heat they produced was ridiculous. I had them Jet Hot coated and under hood temperature dropped dramatically. They were so hot before coating the heat melted my steering shaft universal boot. IMO with the tight clearances headers create keeping the heat down as much as possible is huge.
Old Feb 27, 2022 | 05:16 PM
Ponch85rs's Avatar
Car: 1987 Chevrolet Camaro Sport Coupe
Axle/Gears: 3:42
Ive been looking into the "reverse" double din plates people have been 3D printing and selling on eBay. I am also looking for an adroid compatible radio that will fit into that space, but I am neurotic about fit. It would have to look factory. Has anyone made any progress on this?
Old Mar 1, 2022 | 01:19 PM
scfbody's Avatar
Car: 1983 Z28, 1991 Z28 & 1985 TA
Link to our Reverse double din kit with info on which radios will fit
1982-92 Camaro Double DIN Install Kit (Bezel & Brackets) (screamingchicken.com)
Old Mar 3, 2022 | 05:38 PM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Here a few up pics of the reverse plate. These are molded not 3d printed.im in CT as well if you want to see one in person.
Mailman818
Car Audio
Feb 9, 2012 07:13 PM
salfirebird92
Car Audio
Feb 7, 2011 06:07 PM
burnout88
Car Audio
Nov 16, 2008 01:05 PM
Kandied91z
Car Audio
23
Jun 18, 2005 02:10 PM
85TRANSaus
Car Audio
Jul 15, 2002 04:28 PM
