749 swap part number questions...
Old Jan 27, 2003 | 01:31 PM
Balael6's Avatar
Car: 1988 Formula
Engine: Twin Turbo .60/.63 305
Transmission: T-5 5 speed
Ok got the computer, and the repinning diagrams all figured out. Need some help though guys. I'm looking for a new knock sensor, memcal, and a 2 bar map sensor. Are these the correct part numbers for a 90-92 305 SD setup?
and for the syclone map?
Knock sensor - no idea
Map Sensor - 16009886
Memcal - 16163139
Are these right for the 305? i found quite a few topics for 350's, but none for 305's. Thanks guys.
PJ
Old Jan 27, 2003 | 01:53 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
You will use your stock 305 memcal and knock sensor. You will just need to buy a syty 2 bar map sensor.
Old Jan 27, 2003 | 02:04 PM
Balael6's Avatar
Car: 1988 Formula
Sorry, forgot to mention, i'm swapping from an 88 MAF system.
PJ
Old Jan 27, 2003 | 02:20 PM
YenkoZ28's Avatar
Car: 1991 Z28
Then you'll need a memcal for a 90-92 305 TPI. As for the knock sensor I'm not sure if they use a diff. part between the MAF and MAP. If they do then get one for a 90-92 305 TPI.
Old Jan 27, 2003 | 03:09 PM
Balael6's Avatar
Car: 1988 Formula
OKs cool, gotcha. Are my part numbers correct for these from gmpartsdirect? Thanks again.
pj
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
twest2k2
Aug 24, 2015 11:26 AM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
