$88 bin
Old Feb 6, 2003 | 04:46 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
$88 bin
does anybody have a stocl bin for the 730 ecm $88? my car is a 91, 3.1L, auto. also, where do you change the fuel constant in winbin? one more question, is "730_atta.ecu" a good ecu file to use in winbin for my application? thanks for any help, i'm still trying to learn...got a long ways to go too.
Old Feb 6, 2003 | 07:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: $88 bin
The latest bin for your car is AZTY. There are copies all over the net. The fuel constant is BPC based. This is a term derived from the engine displacement and the injector flow. There is a table that is referenced to EGR flow for this term. Along with two others for crank and idle.
The ATTA bin is an $88 mask also. So the ECU file based on it should match. I've never used 730_atta.ecu but knowing it's origin I'd use it.
RBob.
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
beast94
Aug 20, 2015 06:44 AM
ezobens
Aug 19, 2015 10:29 PM
