Converting to 89 Arap, Need instruction
Old Mar 24, 2003 | 03:11 AM
Stell1579's Avatar
I saw there are countless posts about converting to the 89 arap bin from the 88 bin. I couldnto find clear answeres to my questions though.
I am converting the prom of a 88 305 TPI Auto, The car has a modded exhaust and a 1989 L98 cam. (206/213 0.415/0.430).
What do i have to change in the 350's Arap Bin? I already reset the injector constant to 19.01, I added valuses to 4-8 of the Crank Fuel PW Multiplier vs. Ref. Pulse to make up for the cold start injector. I restet the temps for the fan.
What if anythign has to be changed more for this chip to work flawlessley with the new code? I am not lookign for instructions to make a 100% tuned chip on the first try, just dont wanan blow anythign up and i want my cooling fans and TCC to work right.
I am using Mansur's GMECM Edit to modify my bin.
-Stell
Old Mar 24, 2003 | 07:56 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Tone down the spark tables - they are a bit too aggressive IMO. You are aware that you'll have to disable the cold start injector also? I assume you've done a search and read everything on "ARAP". If not, do so.
Do those things, along with the one's you mentioned and start burning and testing.
Old Mar 24, 2003 | 10:31 AM
Stell1579's Avatar
Yeah i know about the injector. I have read everything on the site about arap. I am a fan of search, Usualy find the answers faster. I just had a few posts confuse me
-Stell
Old Mar 24, 2003 | 11:36 PM
Stell1579's Avatar
Ok, i did some modding to the arap bin. What do you guys think of this
http://members.aol.com/_ht_a/stell15.../arapforta.bin
I checked the N/0 box, Added values to the table so the car starts right, I changed the spark table to a less agressive version based on a 89 305 M6 and 350, Changed the fans to come on sooner. set the injectors to 19.48 and thats about it. Does this have a chance to work decently in a 88 305tpi with the l98 cam? I donot have acces to a programer often so i am tryign to get it good the first time. I am not lookign fo rthe perfect chip, i just want it to run right w/o a ton of detonation and it drinking gas.
-Stell
Old Mar 25, 2003 | 12:01 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
I would run the spark table from this bin.... ftp://ftp.diy-efi.org/pub/gmecm/bin_...6E/AUJL 6E.bin
If you are using the 305 19lb injectors then try a constant of 18.5 or if you are running the 350 22lb ones use 21.5. This should help with the cam and other mods you have at WOT until you get a scanner...
84LsxZ28
May 17, 2020 02:21 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
webeeZ28
Sep 14, 2015 12:00 PM
89fast5oh
Sep 8, 2015 09:55 AM
