4l60-e stand alone computer
Old Apr 20, 2003 | 06:52 PM
maverick351ci's Avatar
Car: 1985 Firebird
i am going to try to make a 4l60-e stand alone computer since i recently picked up a 4l60-e for 50 bucks with 30.000 miles on it i was looking through a gm service manuel and i see that it has a 1-2 shift silonoid
2-3 shift silonoid
3-2 silonoid
vss
tcc siloniod
tcc pulse width siloniod
line pressure silionoid
so it sounds simple i was thinking that if we can use a 165 ecm since we could use the injector drivers for the line presure siloniod and tcc pulse width siloniod and then it would be a matter of relayes for the 1-2, 2-3, 3-2 ones we will need a tps and tach input to get load on the trans or tps and vss but i will need to code a chip to make it work only problem is i lack that nowlage right now but there are some good coders out there i was just wondering if anyone would be up to the chalange of trying to get this all put together
this is just an alturnative to running a diesel ecu (if that will even work) anyways let me know
~Joe Johnson~
Old Apr 20, 2003 | 06:59 PM
funstick's Avatar
first problem the shift seleniods are PWM. second problem the line pressure seleniod is PWM. your best bet is to grab a 4l60E truck pcm 93-95 and just zero out the fuel and saprk tables and use the shift contrroler.
Old Apr 20, 2003 | 07:23 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: 4l60-e stand alone computer
The 165 only has one injector driver.
Diesel PCMs have been used.
My suggestion is, just use a PCM that's meant to be used with that tranny.
You VSS on that tranny would take even more work to be seen correctly by one on the earlier ecms.
Old Apr 20, 2003 | 09:44 PM
Car: 1985 Firebird
ok so i should use either a diesel PCM or a Truck PCM and just zero the engine controls??? witch one should i go with i really dont feel like spending over a grand on a stand alone system?
Old Apr 21, 2003 | 06:12 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Which one can you edit?.
www.tunercat.com has a bunch of the gas truck editoring stuff. You'd have to look to see if he has a Diesel Editor.
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
ericjon262
Sep 11, 2015 06:07 PM
