Map sensor and coil wire
Old Jun 8, 2003 | 03:47 AM
Z_Ghost's Avatar
I know this is not a prom burning problem so if it get locked or deleted that's OK, but I think that I have a better chance of finding out the answer in here.
I have a SuperRam and the MAP sensor is sitting at the very back of the plenum, now I want to mount the coil on the lip of the firewall on the passenger side. The only problem that I see is the coil wire is going to be running right over the top of the Map sensor, I am wondering if this will interfere with the MAP.
Would the coil wire create a magnetic field that could through the MAP off? I will be running MSD 8.5 super conductor wires.
Old Jun 8, 2003 | 06:22 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Map sensor and coil wire
ON a good day and with everything just perfect, probably not. Add some fractures in the carbon filaments in the wires, increased plug gap and higher firing voltages, being lean, and the RF might go hight enough to trash the sensor's output. I've seen heater fans when old generate enough RFI to mess up TPS, MAP, MAF outputs.
Old Jun 8, 2003 | 02:44 PM
Z_Ghost's Avatar
Thanks Grumpy, looks like I will need to make the coil wire a little longer so I can move it away from the MAP sensor.
Old Jun 9, 2003 | 06:53 AM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
Hey Z_Ghost,
Are you going to the Grapevine sonic this coming saturday June 14th at 3:00 pm.
If its not raining I'll be there.
I bringing the Z-28 with the Romulator, WBO2, and my Scan-grafix data loging software, a little show and tell for those that are interested.
Hope to see you there.
Old Jun 9, 2003 | 02:21 PM
Z_Ghost's Avatar
Originally posted by LBSZ28BLOWN
Hey Z_Ghost,
Looks like I am now.
Thanks for letting me know Louis.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
