calculating load value
Old Jun 19, 2003 | 09:24 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Can someone tell me how to calculate the load value based on MAF volume vs. RPM? Is there an equation to do so?
Old Jun 20, 2003 | 06:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: calculating load value
It is basically LV8 = airflow / rpm.
The code is a little more involved:
Code:
        ldx     *L0099          ; Current Minor LP Ref Period
        ldd     *L00F1          ; DISPFLOW, Mass Air Flow gm/sec
        jsr     LF429           ; 16 * 16 Mult routine
        pshb                    ; Save Middle 2 Bytes of Product
        psha                    ; Save Middle 2 Bytes of Product
        tsx
        ldaa    LC5B0           ; Ld VAR FOR SCALING LV8 Scale factors
                                ; 80d = 80/64 = 16
        jsr     LF5B5           ; FACTOR IN 8x16 MULT
        ldd     0x00,x
        rolb
        rola
        bcc     LD742           ;
                                ; ... else
        ldd     #0xFFFF
LD742:  lslb
        adca    #0x00           ; ROUND
        pulx
        bcc     LD74A           ;
                                ; ... else
        ldaa    #0xFF           ; USE MAX VAL
LD74A:  staa    *L0064          ; FILTERED LD VALUE (LV8)
The minor LP ref period is the inverse of the RPM. So here it is multiplied by the airflow, then scaled and saved.
RBob.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
jrdturbo
Mar 31, 2016 02:58 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
efiguy
Sep 27, 2015 01:30 PM
