WOT parameters?
Old Jun 25, 2003 | 11:39 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
WOT parameters?
Hi...
Becaurse you "only" can tune WOT with the PE/rpm table, how does the ecm control pulse width at WOT in the 165 ECM. Is there a "hidden" pre-programmed table of load/rpm inj.pulse?
Does this "table" consider the inj.contant you put in the .bin ( so if you increase inj. const the ECM will shorten the width) or how does it work?
And how about the 730ecm how does the WOT fuel controlling work there? is it only in the VE tables or?
Just curious how things work.....
/N.
Old Jun 26, 2003 | 06:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
When at WOT the code still uses the MAF input. Same with a SD system, the VE table (based on MAP input) is still used. The difference is that the commanded AFR is changed and closed loop & learning is disabled.
In closed loop the commanded AFR is typically 14.7:1. In open loop it may be anywhere from 9:1 to 16:1 (typically). In WOT mode the commanded AFR will be lowered to enrich the mixture.
RBob.
junior419
Apr 7, 2025 11:35 AM
Pac J
May 17, 2020 10:44 AM
86White_T/A305
Mar 6, 2016 01:48 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Damon
Sep 26, 2015 04:29 PM
