Intermittant computer? problems
Old Jul 18, 2003 | 09:49 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Intermittant problems computer?
I have been slowly but surely burning my own chips, Just a few adjustments to the fuel table so far. one day I was driving around and i came to a stop and the Idle started jumping around, and the service engine soon light flashed irradically with no pattern, i tried to accelerate and no matter how much throttle i gave it, it would barely move and them cut out and move alittle more and cut out and it died a couple of times (just trying to get out of the intersection) finally i was able to get the rpms up and after ~1500 and up it was like normal. now It happens at random times, I will be going though a drive thru and the Idle will start bucking and it will die unless i stall it up. also when it is having a "temper tantrem" if im coming to a stop i notice the mph will glitch when the rpms are under 1500. does anyone have a clue about what this might be? it seems to happen at the most inconvenent times also (when taking a girl out on a date )
also I have a SES light that apears randomly when cruising around, I scanned it and it is a code 43 I have no clue where this could be coming from.
I really need to get this tracked down if you guys could help i would greatly apperciate it !!! :hail:
Thanks,
Chris
Old Jul 26, 2003 | 04:33 PM
Dan91Z's Avatar
My car does the exact same thing, except it dosen't get better at higher rpms when it's having it's temper tantrem.. I also noticed it seems to do it only when you don't want it to, like when you are running late for work or are on a date.. I have already replaced the ecm hoping to get rid of the problem but it's still there..
Anybody have any ideas on what might be causing this?
It's a 91 Z28, 305 Tpi, 5spd, stock motor, 730 ecm (no changes to anything in the ecm, orriginal chip). The only other problems it had while I've owned it was a shorted injector 2 years ago, and the tach is past redline when the engine is around 2k rpm. Hmm, now that i think about it when it has it's temper tantrem, the tach doesn't work at all..
Old Jul 27, 2003 | 09:23 PM
Car: 1991 Z28
I found out that it was my ignition module, and I got a good deal on a whole new distributer so I just replaced it. all is good now.
Dan, I would take yours off and get it checked, good luck
FreeSpirit
Aug 29, 2015 05:47 PM
mike_c
Aug 27, 2015 04:32 PM
CORV3TT3
Aug 23, 2015 11:26 AM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
