Knock retard and spark tables
Old Sep 8, 2003 | 04:46 PM
Swapmaster's Avatar
When editing the spark tables how do you judge how much spark to remove by looking at the amount of spark retard?
Old Sep 8, 2003 | 10:26 PM
Swapmaster's Avatar
If it is showing like 6 or 8deg of knock retard do you take out the full amount or more like half of it out of the table cell?
I have searched the posts and have found nothing on it yet.
Old Sep 9, 2003 | 08:30 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
If my search was O.K. : n + 1 or n + 2 degrees (if you see 8º knock retard in your scanner, then take out 9 or 10 degrees at these cell).
Denis V.
Old Sep 9, 2003 | 10:46 AM
johnh's Avatar
Car: 2004 GTP CompG
Engine: L32 SC
I just updated to the ARAP.bin and I see much more knock retard, 5-6 degrees at WOT than with my stock(1-2 degrees) (AUJM.bin). But I did notice ARAP was a little lean(based on BLMs/INT values)....
should I add a little more fuel first, or change the timing tables..first?
Maybe I will do one, the other and both and try them (thanks to the Bin switcher)..
Old Sep 9, 2003 | 11:20 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
johnH, When I was using the ARAP.bin I just cut and pasted the stock timing tables over the ARAP's and it seem to work well, the ARAP's timming tables are just to much for stock heads.
Old Sep 9, 2003 | 12:06 PM
Swapmaster's Avatar
Here is what I have been doing. Keep in mind that I just converted from MAF to SD and started burning my own proms at the same time about a month ago (ie. I don't know what I am doing yet). I take a good long recording of about 1/2 hour of driving and then I add or subtract fuel where needed and remove about half of the knock count where needed. Then do it again and again untill I am at 128 with no knock. There is more to it than that (disable PE ect. ect.) but that's the basic routine.
My next plan is to add 0.4 deg of timing globaly to the spark tables then re-edit the fuel and spark and keep adding and editing untill I feel satisfied. Once I am satisfied with the spark tables I might subtract 1 or 2 deg of spark globaly from the tables to create a safety cushion.
Comments on this strategy would be great.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
