new to PROM burning, need quick advice
Here's the deal, I have an 88 GTA, I just built a motor for it, has like 100 miles on it...it's a 69 350 block bored .030 over...10.2:1 pistons, Comp Cams .464" 222/226 hydraulic flat tappet cam, stock TPI heads and valves...comp cams valve springs, stock plenum and runners and intake, stock injectors...MSD6A ignition box, 2400 stall converter. I have pocket programmer 2 and Tunercat. I removed my EPROM, but for some reason it corrupted the BIN when I tried to load it to the Buffer, does anybody have a stock 88 GTA BIN they can e-mail me? or perhaps a source where I can find one? Also, what should my fuel pressure be set at for this engine combination? I have it at 42 PSi and it seem to run real rich, so rich that the car doesn't want to idle right. Can someone also give me advice on what to change in my PROM to correct the problem and make my can be "driveable?" Any help is greatly appreciated.
Car: Death Mobile
Engine: 666 c.i.
Go to www.diy-efi.org
Look at your BIN's Broadcast Number and then do a search for it at the DIY-EFI site. Let me know if you are still not able to find one.
Car: Death Mobile
Engine: 666 c.i.
The 1988 was a "one only" year ($32B) and the BIN you want is ABYA (350 F-body auto 3.27 rear). I checked my "archives" and I don't have that one.
I have a 1988 Vette auto bin ABTT (Y-body L98 Auto 3.07) and AKFM (F-body 305 2.73s). That's all I can find for 1988 TPI autos.
I have lots of 1988 Vette manual bins and tons of 1987 and 1989 but no 1988 F-body 350 3.27s.
Make a new post asking for "an original 1988 F-body 350" bin ABYA and see if anyone can help you.
If you don't have any luck you can then consider using the 1988 Vette Auto Bin (ABTT) which I can give you or convert to the 1989 (remove cold start) and use some of the many 1989 350 bins that exist.
