idle knock (7730)
idle knock (7730)
looking for advice how to turn off knock retard for 7730. Getting 4-6 degrees at idle. No other knock. Once off idle its zero. Running pretty aggressive timing table except for idle ,tried running under 20 and still had knock.
How can I turn off the retard for idle.
I see the 2 fields. one for PE mode and the other for KPA.
My setup is agreesive. 383 solid roller. So it does have some noise to it.
Dennis
Dennis
Car: check
Engine: check
Transmission: check
Re: idle knock (7730)
Dennis
Dennis
Code:
L820A: FCB 68 ; 850 RPM, IF >= ENAB KNOCK
; ARG = RPM/12.5 Thanks Rob,
I asusume I can change teh 850 to 11 or 1200rpm.
I have never adjusted the true source code. I take it I would need tunercats bin editor??
Dennis
Dennis
FormulasOnly
Sep 10, 2015 09:07 PM
