i notice on datamaster that my even with
low blm numbers my o2 sensor is reading
between .100 mv - .650 mv which would
say i am on the lean side and my butt meter
says its lean ( the more you push on the gas pedal
it takes a moment for power to accelerate )
am i correct in that low blm's are normally a
rich condition ?
mike
rich condition ?
mike
rich condition ?
mike
In closed loop the O2 voltage just toggles from high to low. The realtionship of rich to lean as a function of that, takes the ecm to interupt. High Bls means the ecm is correcting for a lean condition, and low BL means things are rich, and it leaning things to compensate.Originally posted by turbotater
rich condition ?
mike
The stock O2 is poor for saying anything more then things are richer or leaner then 14.7.
i have a lambda meter as well
and it shows cruise a/f's of 14.8>15.2
i also have a bad lean spot on throttle
tip in from lower speeds or high vacuum
conditions where it jumps as high as
17.1 for a moment .. i have decent a/f on the lamda
under harder accelerations from 11.6> 12.7
there are two tables to deal with this as
i see it using tunercat software , one being accel vs map
and accell vs tps .. is there a preferred choice ?
this is on a 747 ecm .
mike
mike
