Knock counts without spark retard?
Old Oct 1, 2003 | 09:57 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
I was doing some datalogging yesterday, using Datamaster. During playback I like to check and see where the knock counts are, spark retard, map and rpm. This tells me if I need to learn how to drive, or if I need to pull spark or add fuel. I noticed that I gained two knock counts, with no spark retard. Now I've seen spark retard of like .1 or .3 with no knock count, but not the other way around.
Any ideas or should I just shut my mouth and go home?
Old Oct 1, 2003 | 11:08 PM
funstick's Avatar
if theres not enough instance of knock iun a certian time frame there will be no retard but the knock sensor it self being active will show up on a scan. also the knock retard could have been so short and minimal that it wasnt in the data stream.
Old Oct 2, 2003 | 12:22 AM
HaulnA$$'s Avatar
What you are seeing is the ECM doing its knock sensor test. It will test for knock without activating the knock retard routine just to make sure the knock sensor is working.
Old Oct 2, 2003 | 03:12 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
interesting thought about the ecm performing a test on the sensor itself, as I had already accumulated 5 knock counts, with spark retard within the 15 mins or so of data I had collected.
Guess I'll just ignore it and continue to play with it
thanks
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
