quick question from a newbe
Old Nov 10, 2003 | 12:35 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
What is it that the Volumetric eff. adder tables do? how are they different from jus the VE tables?
Old Nov 10, 2003 | 01:41 AM
cali92RS's Avatar
Car: White KSwisses
Okay, i think i got the answer. The two tables are just added together.
Is this why people add the values from table2 to table 1 and 0 out the second table (from 400-3200 rpm)? Am i correct in these assumptions, or am i off?
Thanks,
KD
Old Nov 10, 2003 | 07:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Thanks,
KD
Yes, just add the two tables together. Before you ask, once over 3200 RPM the last row of the 3d table is used along with the proper RPM row of the 2d table.
It isn't proper to zero out the 400-3200 rows of the 2d table. Doing this prevents the tuner from being able to decrease the VE% as the RPM increases. I've found it best to set the 2d table 400-3200 RPM range to say 40%. This does two things, one, makes it easier to compare the VE% row to row on the 3d table. Two, gives the tuner the ability to decrease the VE% as the RPM increases.
By 6375 RPM on a stock or even a mild engine is liable to be down that 40% VE that is currently in the 3200 row of the 2d table. Remember that at 4800 (anything above 3200) the 3200 RPM row of the 3d table is added to whatever VE% is in the 2d table at the current engine RPM.
RBob.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
