newbie questions
Old Nov 18, 2003 | 10:04 PM
proryder2's Avatar
Car: 73 chevy truck
Engine: 406 11.6 comp 2.02 heads
Transmission: stock th350
newbie questions
im am putting tpi from a 88 camaro into my 73 chevy truck with a built 400. i was wondering if i can use a wiring harness that has the four wire hook up like the ones from painless or chevy thunder.com and if it would still work for tuning. also do i have to change anything to go from the maf to sd i already got the 730 ecm and all the sd senors do i have to change the prom in any way. what all do i have to change on the prom just to get it to run so i can start tuning. i know injectors and an vats and maybe smog stuff but im not sure how to do that can anyone explain. where can i get a cold start injector block off? can some one explain what the ve thing is all about?
thanks for you help!
Old Nov 18, 2003 | 11:12 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
I have an '88 engine and an 87 car that I switched to SD.
I don't see why that harness wouldn't work for a 7730. Just make sure you get the harness for the speed density set-up. Someone else should be able to verify this.
All the sensors from the 88 or the SD set-up will work except the knock sensor from the 88. You'll want to use the SD KS. And of course you know that the MAP replaces the MAF.
In addition to changes you already listed for the Prom, you'll also have to change the engine size in the chip. If you have a hefty cam you might want to raise the idle speed right away also.
Ditto the cold start block off kit. I'm looking for one myself since mine leaks and an O-rings cost $128 because you have to buy the friggin kit. Right now I'm planning to tap a 1/16" pipe thread into the steel plug that goes into the fuel rail. I've bought some 1/16" plugs and tap already. Just have to make a plate for the valve.
Old Nov 18, 2003 | 11:15 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Mike Davis has a good site for doing a swap to SD.
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Old Nov 19, 2003 | 10:48 AM
proryder2's Avatar
Car: 73 chevy truck
thanks for the help what programs do you suggest i should use and how do i change the injectors and change it for the different engine size. im going to buy a pocket programmer 2 and a cable from moates i think it was to hook it up to the lap top. i just don`t get how to make the changes. all i see is this like 8$ stuff everyones talking about and thats confusing.where did you get that kit from and whatsit called? thanks foryour help
Old Nov 19, 2003 | 10:48 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
http://tunerpro.markmansur.com/
Download this software, open an AUJP bin, use a 8d ECU file. Look through some of the "constants" and you'll find the one for the engine size. There is a table for the idle speed vs. coolant temp.
Old Nov 20, 2003 | 09:49 AM
proryder2's Avatar
Car: 73 chevy truck
i don`t get how to change the cylinder size its says like 70.21 or something not like 350.00 or something like that.i got the aujp bin file and the 730 ecu file please explain the numbers to me please.
thanks
Old Nov 20, 2003 | 08:41 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Cylinder displacement refers to the displacement per cylinder, not total. 350/8=43 cubic inches or 5700/8=712 cc
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
R3500
Aug 24, 2015 09:05 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
