ECM Bench and another question
Old Dec 9, 2003 | 07:56 PM
87_TA's Avatar
Every day I am seeing more of a reason to have an ECM bench, Just wondering if you can change coolant temp reading anyway?
I am really interested in the effect of coolant temp on PW and cell activity.
The other question, I may have damaged my L1H1 - Any way to test it?
Old Dec 10, 2003 | 12:31 AM
91L98Z28's Avatar
Car: Z28
with regards to the L1H1, i think (if i remember correctly) one way of testing to see if it does anything at all is to hook it up to your wbo2 and use a lighter to deprive the sensor of oxygen, and you should see the reading change. check through the diy wbo2 documentation to be sure.
The coolant temp is just measured as a resistance across the sensor, you should easily be able to set up a variable resistor to set the coolant temp to anything you want.
Old Dec 10, 2003 | 09:07 AM
11sORbust's Avatar
from what I understand things like the coolant temp is set by a rotary switch. I agree that an ecm bench is looking very usefull. This place is starting to feel like da MOB! I just keep getting deeper and deeper in this game. I thought I would just learn how to tune my car. But there is soo much going on(in the ecm). AND I'm the type to learn all I can...
Old Dec 10, 2003 | 01:27 PM
91L98Z28's Avatar
Car: Z28
oops - yeah, i guess a variable resistor was a bad term. I think they are usually called poteniometers or maybe rheostat. basically just a rotary variable resistor.
there is defiantely a ton of stuff you can do. I am still procrastinating writing the code that will control my t56 reverse lockout based on speed...
Old Dec 10, 2003 | 03:57 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Yes all you need to change the coolant temp is a pot. 10K usually works well. BW
Old Dec 10, 2003 | 11:10 PM
11sORbust's Avatar
10k pots are good for realtime calibration check by driving and simulating different temps to the ecm.
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 10, 2015 08:42 AM
