no start / hot start / long arap start
Old Dec 12, 2003 | 01:44 AM
NoWaySS's Avatar
Well I dont know if this will work for all but i have been having a major starting problem with my vortec headed 350 maf 24#inj setup for 2 years now, it didnt want to start cold or hot without aid of starting spray, so after many proms and bullsheet fixes i ended up ordering a carb and intake , well low and behold i figured after a 12 pack of cold ones that maybe ill give my poor excuse for prom burning just one last try and low and behold ill tell you what i did, Now my setup wanted fuel at startup so i went into CRANK FUEL PW VS TPS and set the multiplier for 0 % TPS from 1 to 2 , well low and behold i was stunned to watch the car fire right up only after about 2 cranks, well i couldnt believe it so i slapped myself silly and let the car warm up and started at different temps, HOLY COW ! its starting without a case of the juice! Anyhow I do not believe myself to be a expert prom burner by any means but if this can help anyone out of the situation i was in for 2 years, well have at it!
Good luck to all !
Noe
Old Dec 12, 2003 | 08:21 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
FWIW - this has been covered in detail on this board on a number of occasions. I just did a search to find the info and found it without a problem. Did you try searching the board before ordering the carb?
Tim
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
