DIY-WB Building - What is CalR connections for?
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Where do the CalR connections from J9 and J10 go to? I didn't want to buy a honda female sensor connector but where do these lead to? They look like they dead end inside the connector.
Car: An Ol Buick
Engine: Vsick
Re: DIY-WB Building - What is CalR connections for?
The calibration resistor is in the WB sensor's connector.
There are 7 wires that go to the sensor's connector, and then the sensor has 5 wires running to it. The 2 *extra* wires are for the calR.
Thank you Bruce. I was able to take the resistor out of the connector housing and I will mount it inside the enclosure.
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
I'll take note of that SATURN. Quick question so I don't have to start a new thread, what fuse rating are you guys running? I have a 3A now but wonder if I should go lower or higher. Thanks
Car: An Ol Buick
Engine: Vsick
