WBo2 tuning radical camshaft
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
I'm going to start tuning with a WBo2 next week. Would you install the WBo2 in the X pipe or would the drivers side collector work just as well?
If you're interested, this is where I'm at so far with the GM o2 sensor:
Tuned with CATS, scanned with Datamaster 8D
WARNING: Drastically modified 730SD PROM File - Do not USE it!
http://members.sigecom.net/smaster/3.Bin
The best closed loop tune I've accomplished for the street, so far.
http://members.sigecom.net/smaster/0227-1.uni
SBC 383 w/TFS 23° aluminum heads, full roller, 11:1 SRP's.
CC306 camshaft w/1.6 RR 290/307 Duration @ .006 & .544/.576 Lift
730SD w/30# SVO injectors, 58mm BBK, Holley Stealth Ram intake manifold
700r4, 3.73 gears w/Vigilante 3200 stall. 4040# GMC Pickup truck.
Best 1/8 mile: 8.35/83.80mph w/1.88 60' w/stock suspension
Craig Moates multi adapter - AM29F040B Chip
BTW, thanks guys, I couldn't do this without Thirdgen.org!
