Stay Alive Memory (SAM)
Old Feb 28, 2004 | 08:53 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Can anyone explain what SAM is? I noticed that there are a couple coolant params that indicate when SAM is active. For the stock AUJP it begins at 197 F and ends at 220 F. What is it?
Also notice the parameter for the idle cell (cell 4 stock).
Tim
Old Feb 29, 2004 | 12:19 AM
funstick's Avatar
if my reading from the archive is correct its a non vollitile ram where stuff like IAC park posistion etc is stored for future use. even learned block learn is store there as well i do belive.
Old Feb 29, 2004 | 07:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Stay Alive Memory (SAM)
Tim
Briefly covered in this post: https://www.thirdgen.org/techbb2/sho...hreadid=221558
It allows two BLM cells to be saved during ignition off. One being the idle cell the other being a common cruise cell. If data has been saved then at the next ignition on those two cells in the BLM matrix will be loaded from the SAM cells. Else those two cells (like all the others) will be set to 128.
RBob.
Old Feb 29, 2004 | 08:22 AM
TRAXION's Avatar
Thanks Rbob for posting the reference. Geez. I replied to that only a month ago and I already forgot about it Sorry. I should have searched.
Tim
Old Feb 29, 2004 | 02:42 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
wow im honored ,my first time being referenced in a post :-)
thanks guys
Jeremy
sheachopper
Jul 31, 2019 11:27 AM
Vintageracer
Sep 24, 2017 12:34 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
lewandom
Oct 1, 2015 08:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
