Is this really necessary?
Old Mar 20, 2004 | 07:38 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I found this table in my '8063s calibration.
;-PE AFR corr. factor vs. %TPS
; Factor =val. /128 ;%TPS
LD38B FCB 133 ; 60
FCB 134 ; 70
FCB 142 ; 80
FCB 139 ; 90
FCB 128 ;100
And of coarse code that multiplies the WOT AFR times those correction factors and divides by 128. Why did they put this in? What would it do for the car? Maybe to help lean it out under moderate loads? Its not in the later 8746 calibration. All it does for me is make the motor run different at different loads. Like sort of flat in the middle and leaves a trail of black smoke with the pedal to the floor.
Old Mar 20, 2004 | 08:06 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That is strange. Can't really see a need for that table. 128's across the board look good.
RBob.
Old Mar 20, 2004 | 08:37 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Jsut got back from a quick spin with only 128s and its much more uniform. Wonder why they put it in? Maybe to give an extra measure of control over the AFRs in PE?
Old Mar 20, 2004 | 09:56 PM
11sORbust's Avatar
I don't know how to read code very good. But it looks like the "line" for wot a/f correctons. Ya know, if the blms are leaner than 128 then ecm adds fuel? Maybe that table is the amount of correcton based on tps??
Old Mar 20, 2004 | 10:03 PM
Car: 88 Camaro SC
Engine: SFI'd 350
just for yucks, heres what the code looks like
LDX #$D38B ;Corr. factor vs %TPS table
LDAA L0043 ;%TPS
;-Scale %TPS for lookup
LDAB #$00A0 ;160
MUL ;(%TPS x 160)/256
ADCA #$0000 ;round if needed
LDAB #$0060 ;96
JSR LFB77 ;2D lookup with SBA
PSHA ;corr. factor ----> stack
;Look up PE AFR
LDX #$D386 ;PE AFR vs RPMs
BSR LDAC4 ;Lookup subroutine using scaled rpms
;-Do %TPS corr. to PE AFR
PULA ;get %TPS corr. factor off the stack
MUL ;%TPS corr. factor x PE AFR
ASLD ;x2
BCC LDAF1 ;BRa if no overflow
LDAA #$00FF ;Clr overflow
LDAF1 TAB ;(TPS corr. factor x PE AFR)/128 ----> B
Ive been fighting this for awhile. I always got fluctuating 02s with varying throttle load and I could never figure out what it was. Im really glad I came across this because it sort of bugged me to have varying performance.
Old Mar 20, 2004 | 10:11 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Thats probably something along the lines of what they over at GM intended. To give some correction for changing throttle or something. Who knows...
