Can someone lend me the injector offset vs voltage table for a 165?
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
I am reprogramming a 302 that I am using with a 3.4L V6. I am using the injectors for a 350 TPI that was mated with the 165. I am been reading into this and discovered that GM uses the injector offset table as the primary control for the injectors. I like would to compare the table from the 165 to that of the 302. I am running rich obviously and I would like to see if there's a difference.
Thanks,
Jim
Thanks,
Jim
rb85TA
26
Sep 14, 2015 10:29 PM
