DIY WB-O2 V_reg replace w/ LT1764
Old May 22, 2004 | 02:47 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I am looking into replacing the main voltage regulator (LT1086) on the DIY WB-O2 kit with a Linear Technology LT1764. There are a few differences. Using the LT1764 would allow for less input voltage from the battery (approx. 1 volts less than the LT1086). This would make the min. input voltage 12.7 - 1.0 = 11.7 volts.
The main differences are:
LT1086 LT1764
curr. limit 1.5 A 3.0 A
v_ref 1.25 V 1.21 V
v_drop_out 1.5 V 0.7 V
Can the NTK WB-O2 handle the 3.0 A current upon start-up?
I also need to check what resistors may need to be replace for the v_ref change from 1.25 volts to 1.21 volts.
It seems to me that the LT1764 would be a good replacement for the existing LT1086.
J
Old May 22, 2004 | 03:52 PM
junkcltr's Avatar
Engine: 3xx ci tubo
The LT1963 seems like a better choice.
Only need to check the 1.21V reference. LT1086 has a 1.25V reference.
Old May 22, 2004 | 07:10 PM
AlexJH's Avatar
Engine: 5.7L V8
Re: DIY WB-O2 V_reg replace w/ LT1764
Originally posted by junkcltr
LT1086 LT1764
v_ref 1.25 V 1.21 V
The max current is the max that it can supply, it won't force 3A through the circuit.
Old May 22, 2004 | 08:58 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Correct.
WB cold = approx. 3 ohms
WB voltage = approx. 10.5
current cold (not limited) = 3 amps
LT1086 current limits it to approx. 1.5 A
Old May 22, 2004 | 11:09 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I looked at at the DIY WBO2 circuit and figured out the answers.
1) The regulator output resistor does the current regulation so either of the regulators I was asking about would work
2) The v_ref change would make the warm-up time longer. This could be resolved by adding more parallel resistance with the output resistor.
*** Neither device would work because the ADJ pin is clamped to +/- 7 volts *** It would take a circuit redesign in order to use the different regulators. Oh well, it was a thought.
J
