Tuning a xe262h10
Old Jul 11, 2004 | 03:31 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Tuning a xe262h10
I'm buiding a 350 for the vert and would like to use the above mentioned cam. It is a 218/224 with a 110 lsa. Will be using vortecs with a vortec stealth ram (which will hopfully be available by this winter). With the short intake duration of this cam do you see the 110 lsa being a problem? It is supposed to pull 19 inches of vaccum @ an 800 rpm idle.
Old Jul 11, 2004 | 04:08 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
It should be feasible to tune it. Itll probably take some work but in the end it should run real nice. I was going to get the same cam and a set of vortecs myself before my transmission crapped out.
Zell1luk
Sep 29, 2015 10:36 AM
