hot start issue
Old Jul 12, 2004 | 07:44 AM
scottydta's Avatar
Car: 1989 Trans Am
Transmission: 700R-4
hot start issue
now that north carolina's summer heat is here, been having some warm and hot start issues. cold first start of the morning is fine. after it warms up and sits for more than 10 min., it takes a solid 15-20 cranks for her to fire. have gone high and low values with crank fuel tables and startup spark to minimal improvement. if i crack the throttle after a few rotations she will fire up. if thats the case should i consentrate on increasing the reference pulse table since the crank fuel vs. TPS is a multiplier value? anyone with a similiar combo have this issue?
using stock based 6E bin
Old Jul 12, 2004 | 10:21 AM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Sound like you have a fuel leakdown into the intake (FPR / Injectors). Does the exhaust have a grey/dark color to it when it fires after sitting for that amouont of time?
Old Jul 12, 2004 | 10:52 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
The otherthing that you can do if you do suspect fuel leak down is to hold the accel. petal to the floor when starting it. It is the flood clear mode (basically it will prevent the injectors from firing on start up and should allow you to start the car more quickly).
This is not a fix, however, if it fuel leak down it will help get it started more quickly until the injectors are replaced.
Old Jul 12, 2004 | 12:04 PM
87_TA's Avatar
If it seems to like the air when cracking the throttle, you may want to try less fuel or look at IAC counts on start up.
Old Jul 12, 2004 | 12:43 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: hot start issue
Might crack the min idle speed up a tad, or add some IAC counts. Sounds like it's too rich or not being able to spin up enough.
Also, as a remote thing, there might not be any spark when just running on the modile, ie the EST line stuff is fubar'd. So at over 375 RPM the EST goes active and then the engine will start.
Old Jul 12, 2004 | 04:22 PM
scottydta's Avatar
Car: 1989 Trans Am
leakdown was my first suspicion. when i swapped out for the superram, i pulled the fuel rail and watched to see if i had any leakdown and all was good at 48psi.
right now i am running 60-70 steps at idle. should i open up the TB a little to get the IAC's up towards the 140-150 range? i am also parking the IAC at about 50 counts because that is where it likes to currently idle when warmed up. thanks for the reply's
Old Jul 12, 2004 | 04:27 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
My cars started better when I aimed the IAC for 120-125 steps. This was a large improvement.
Old Jul 12, 2004 | 10:11 PM
87_TA's Avatar
If your idle steps are 70 then that is a little high, You may actually want to open the T/B which may help your initial problem.
Try to get idle steps down in the teens and see how that works.
But I was not speaking od Idle steps before, I was speaking of startup steps.
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
