749 Spark table question...
Old Aug 7, 2004 | 09:52 PM
Balael6's Avatar
Car: 1988 Formula
Engine: Twin Turbo .60/.63 305
Transmission: T-5 5 speed
The main spark table in the 749 code for the sy/ty seems to have a LOT less advance then the stock 305 bin for a sd car.
I was wondering if it would be a good idea to swap the timing tables into the 749 code from lets say the aujp bin, and calculate the rest of the tables in the 100+ kpa areas based on the current numbers there in the 749 code? THe 749 code has other areas that have effect on advancing and retarding the spark based on kpa, and boost levels?
Anyone else done this idea with the 749 code and the spark tables?
PJ
Old Aug 7, 2004 | 09:57 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: 749 Spark table question...
Tuning is about making an engine happy, doesn't matter what you start with, it's the final table that matters.
Old Aug 8, 2004 | 01:40 AM
1981TTA's Avatar
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
That's as good a starting approach as any. If you have some knowledge (or a good "feel") for what the spark advance should be, by all means change the table. Remember, if in doubt, stay conservative....
Yep. There's a table to modify spark based on MAT and boost available, too.
Old Aug 8, 2004 | 11:42 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
In $58 there is also a "SA retard vs Boost vs MAT" that takes out 1.8deg as soon as you go into boost.
(if I'm reading it right...)
/N.
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
