Emmisions good on S_AUJP
Old Aug 9, 2004 | 01:58 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I just returned from emmisions testing and all is good!
ITEM READING LIMIT
HC 64.6 144.0 PPM
CO 0.10 0.92 %
NO 313.6 1014.0 PPM
Co2 13.23 N/A %
This was amazing due to the following points.
CCP not enabled,
EGR solenoid not installed,
Air Injection disabled (solenoids unplugged)
fuel pressure at 50 psi,
This is a 350 TPI, not a 305 CCC carb motor as registered!
195 T-stat, running 93 octane.
>145 IAT temp during the test to top it off.
This tune was not that difficult to get when starting with a good base file.
Man, many thank to the guys who have helped to put this together escpecially Traxion, Ghost69.
Also kudos to Craig and Mark for thier hardware and software!
All you guys who have put up with me here as well
Without all you guys, I'd still be monkying around with an obsolete Accell setup or would have gotten fed up and put a carb on the thing
Now I have two years to to whatever it takes to go faster.
(insert devious laughter here-> )
SuperCharger AUJP ?????
Ghettobird52
Jul 5, 2024 11:18 PM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
89fast5oh
Sep 27, 2015 09:04 PM
ezobens
Aug 19, 2015 10:29 PM
