$6e datastream ?
Old Sep 3, 2004 | 11:01 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
$6e datastream ?
Is it possible to have the $6e code display the tps% as well as the tps volts in the datastream using datamaster and/or tunerpro rt as it does in the $8d version of datamaster.
Old Sep 4, 2004 | 12:10 AM
smokeingGTA's Avatar
Car: 89 firebird GTA
Engine: 350 T.P.I
Transmission: 700-r4
I use ecm852 for moates and it shows both with 6e code
Old Sep 8, 2004 | 03:07 PM
eric305TPI's Avatar
Bringing it to the top
Old Sep 8, 2004 | 07:49 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
absolutely. open the tunerpro datastream def edit, set the operation for the TPS to "percent", set the max to your TPS sensors max (4.30 or so), set the min to your TPS sensor's min (.55 or so).
That will do it.
If you want both displayed, create a new item, copying the parameters from the existing TPS item, then make it a percentage operation as explained above.
Overkill
Nov 24, 2007 04:08 PM
David Petersen
Jul 11, 2007 04:50 PM
96HawkCnvt
Sep 16, 2006 05:02 PM
Kwik89GTA
Sep 14, 2006 05:19 PM
First/Thrid Gen
Apr 24, 2005 10:03 AM
