Tuning with a WB O2
Old Sep 11, 2004 | 12:47 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Tuning with a WB O2
I want to get a WB O2 in the near future. My question is How do I tune WB? Is it mostly for tuning to get 128 BLM or only for PE or both? If I use it for non PE should I go with what the WB says vs the NB? If that is correct and I change the VE tables to reflect the WB wont the ecm still try to correct to what it thinks the NB reads?
Thanks, I have been reading on this for a while but still a noob.
Old Sep 13, 2004 | 02:51 PM
Ronny's Avatar
i have had mine(WB) now for a couple weeks. i worked on my VE tables past year without WB and see no reason to change them or reapproach them. the WB showed me i was way rich on AE. i have reduced AE now 3 times(10%, 5%, 5%) with positive results each change. WB confirmed my commanded PE at 12.7 to 13.0/1. that was set in constants at 12.75/1. my 02 sensor contionues to set my CL at 15/1 to 16//1 depending upon how much heat in my intake manifold. i suppose i could change that to 14.5/1 CL but car runs well at 15/1-16/1 and possibly fuel mileage is improved a bit. also running as bosch 02 so maybe that is why higher than should be. will reapproach my VE tables when the new cam goes in this month.
Zell1luk
Sep 29, 2015 10:36 AM
