aldl port q's
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
aldl port q's
interesting question for you guys. I just switched my car over to tpi and was wondering what pins at the aldl port it will use. I have a connector that just has two wires instead of a plug end so before I just pluged one wire into the A port and one in the M port. will this change now that I am using the 730 ecm? I guess I should add that I used the S&P integrator harness for the swap so I am still using the TBI harness for the car. I don't want to screw anything up by pluging into the wrong port (if that is possible)
