Data Log
Old Sep 30, 2004 | 06:52 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Data Log
I have been here for awhile and Understand Most of the basics, hardware, software, ECU & Bin Files and types but havent really had time to Data log So that I can actually start Tuning.
So here is my data Log, please review it and give me comments and direction, thanks
DataLog
You might need to right click and Save As.
Old Sep 30, 2004 | 11:44 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
From another novice tuner...
Your BLMs look alright though they all seem to indicate correcting for a lean conditon so you may want to add some fuel.
O2 also seems to like to hang around the lower numbers most of the time which can be seen if you plot it. Not quite sure what that indicates. How old is the O2?
One oddity I see is that you pick up knock counts but no knock retard. Anyone have any ideas on that? Either way once you get the BLMs in line you'll probably want to take a look at the knock. It looks to only occur under mid to heavy throttle so it's probably an AE and/or PE problem.
Old Oct 1, 2004 | 05:24 AM
conv90's Avatar
Car: superrammed V
Engine: 396 SBC Speed Density
Axle/Gears: Dana44 3.45
why your Vehicle Speed is always 0?
Old Oct 1, 2004 | 05:48 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Well I was in a hurry when I posted the first time, had to go to work, I hate 3rd shift. Well I have what I consider a Bad MAF sensor, It stumbled and had a horriable hesitiation and set a Code 33, So when I took the datalog I had the MAF unplugged and car ran Good, and the Speed thing, I have a 85 and the VSS is on the back of the guage panel And I just had Gotten done cleaning up some wiring Which was uneeded Like Cruise Control and a few other tid bits of wiring So there was No dashboard in car or Guage Panel so that is why the Speed was 0.
I was pretty suprised at the BLMs considering that the maf was unplugged and it was in closed loop at Engine Run 415s
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
