parallel cable?
Old Oct 16, 2004 | 03:30 PM
2new2funny's Avatar
parallel cable?
Has anyone had any success using a db 25 cable instead of a serial db 9?
Is this an alternative to people without serial connectivity on their laptops?
Old Oct 16, 2004 | 04:01 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Parallel and serial are two different things. Dont think there is a way to utilize the parallel port for this. If your laptop has a usb you can use that with an adapter. I imagine it must have some form of a serial communications on it. Even my tandy with an LCD dot matrix display and DD 3.5" floppy drive had a serial port.
Old Oct 19, 2004 | 08:17 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
no, a DB25 will not work with parallel port. They have different methods of communicating. Serial data is transmitted sequentially 01010110101 - one bit at a time, and a parallel port is bi-directional and relies on two way communication.
If your laptop has PCMCIA Slots sometime called PC Card slots -- you can pick up an RS232 adapter for less than 50 bucks.
Old Oct 20, 2004 | 03:48 PM
2new2funny's Avatar
Are these the slots that take wireless cards, for example?
Old Oct 20, 2004 | 05:22 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
yep, thats them. On 'most' latptops I've seen they were on the right hand side of the case -- and each slot, usually 2 stacked one on top of the other, has a spring loaded ejector.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
