Got a new toy in the mail today.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
My late model MAF sensor came in. Got it off of ebay for 30 bucks and it appears to work so its not too bad a deal. All I can say is this thing is friggin huge! The opening is about 3.5 inches across. Lot more flow capacity then Ill ever need. Should be interesting to tune it. I dont ahve the tables for this sensor so Ill have to use the BLMs and forcasting to rough the tables in. I cant wait to try it out.
A few pics...
A few pics...
Car: An Ol Buick
Engine: Vsick
What I did, was take a 3" housing, and cut the foil out of it, and then ran the 3.5" sensor's guts, in the small housing. Had to trim a few locating nibs, but no biggie there.
BTW, they read down low enough that a lil 231 meters fine on them.
Remember you gotta match the freq range of the sensor to the ecm in use.
Car: 88 Camaro SC
Engine: SFI'd 350
Im going to be using a frequency to voltage converter so I can easily read it in with my tbi ecm. Seems like the easiest way. From the tables I have the resoultion is ok at low flow rates but it gets bunched up above around 200 grams/sec or so. Ill probably use a venturi adapter of some sort so I can adapt the smaller inlet of the tb hat to the rest of the larger plumbing. Id like to ultimatly make a custom tb hat that has a large 3.5 in opening on it. Should be able to easily feed whatever I throw at it.
Car: 88 Camaro SC
Engine: SFI'd 350
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
