454 and 700R4 with 1227747
Old Oct 25, 2004 | 09:04 PM
yellow73bb's Avatar
I suspect that this has been answered before, but I can't find it anywhere.
I put a 700R4 (updated for the power/torque) into my car behind my 454. I have a 1227747 installed. I have a couple questions:
Did GM ever put 1227747 into a truck with a 7.4L and a 700R4? Or just the T400?
Which is the best bin file to use with my combination?
Thanks for the help.
John.
Old Oct 25, 2004 | 09:17 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Since the 350TBI pickups used the '7747 and the automatics were all 700-R4's, it may be easier to take a 350 .bin and modify it for the larger displacement than to try to find a .bin that may or may not exist.
Just MHO.
Old Oct 25, 2004 | 10:36 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
what did the 454 ss trucks use
Old Oct 25, 2004 | 11:01 PM
yellow73bb's Avatar
A little internet research indicates that the 454SS trucks had a TH400(E) the first year and then the 4L80E after that. I have not been able to find any information yet on what the difference is between a TH400 and a TH400E.
Did the 454SS have the 1227747?
Old Oct 25, 2004 | 11:02 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Why do you need this bin any way, and yes I believe the 454ss had a 700r4.
Good luck finding a bin though!
Old Oct 25, 2004 | 11:06 PM
yellow73bb's Avatar
I want the ecm to control the lockup in the 700R4. If all the 1227747 based 454s drove TH400 transmissions, then can I still control the lockup torque converter on a 700R4 with the bin?
Old Oct 25, 2004 | 11:13 PM
TheGreatJ's Avatar
All 7.4's from '87-'89 had the '7747. Starting in '90 they got the '8747, as well as the '7470 and '7060 from '91-'93.
Seriously though, if you have a chip burner, just use a TBI350 vin K '7747 .bin and import the calibrations (except for the tranny stuff) from your current .bin.
Old Oct 25, 2004 | 11:35 PM
yellow73bb's Avatar
I guess I could, but my current bin is for a standard (4-speed). Isn't the spark table different in the auto?
Old Oct 26, 2004 | 12:29 AM
JPrevost's Avatar
Car: 91 Red Sled
Yes the spark tables are different but that's not an end all. It'll be closer than starting from stock. Take a look at the differences that GM made between equal drivetrains except trans. You'll find a good start that way. What kind of work have you done to the 454?
I'll search my bin library and see if I can find a 7747 454 manual calibration. But if not, I'll do a quick compare to see the GM did universally.
Old Oct 26, 2004 | 05:42 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The truck calibrations are so miserable, that I'd suggest using a 350 auto .bin, and then look at the BPC, VEI+II tables, and main sprk from a 454, and import them into the 350 .bin. Then tune as necessary.
Be sure to run a search for 454, and 747 here, and catch up on all the patches, and details about that engine/trans..
Old Oct 26, 2004 | 08:25 AM
yellow73bb's Avatar
Thanks for the help. I've been tuning for a couple of years (off and on) with a 454 manual bin. I'll start with a 350 auto bin.
It'll be a few days yet till I get my exhaust back on my car, and then I'm taking a vacation for a week, and then I hope to get to work on tuning again.
John.
Old Oct 26, 2004 | 09:07 PM
yellow73bb's Avatar
So much for taking a few days -- the side pipes arrived today, they are on, and they sound SWEEEEET!
Is any of the 350 auto bins better than the others?
Thanks,
John.
Old Oct 26, 2004 | 10:07 PM
TrevorH454's Avatar
Car: 1990 454SS
Engine: 454
Transmission: TH400
All 1990 454SS's had the 8747 with TH400, the 91-93s had the 7060 with 4L80E. My 1990 had a 700R4 that I put in, until I killed it - went back to the TH400, one day will do the 4L80E. My 1990 also has a 7060, but I put that in too.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
