ANHT Data difference
Old Nov 23, 2004 | 07:38 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Looking at the ANHT hac at the table at L834B.
The header indicates 12 values as does all of the other tables of data for the TCC control points.
This table has 13 points!
I am comparing to the AUJP I disassembled for commenting and I have an "extra" $FF at the end of the table that is shifting my line numbers. My data is lining up after that point in patterns that seem to match up but like I said, they are 1 line off now.
The ANHT has 2 points entered in the table for the 44 MPH or 2000 RPM point, but they do have different %load values.
56 and 82.
What gives?
How could lookup be done on two lines with the same values?
Old Nov 23, 2004 | 07:43 PM
JP86SS's Avatar
; LOAD LIMIT vs MPH or RPM, 12 lines
; (HI GEARS LOWER THRESHOLD)
; TCC LOCK/UN-LOCK vs MPH or RPM
; 700R4
; TBL = %FULL LD * 2.56
; % LD MPH RPM
L834B: FCB 36 ; 14 12 400
FCB 36 ; 14 20 800
FCB 36 ; 14 28 1200
FCB 36 ; 14 36 1600
FCB 56 ; 22 44 2000 <--------
FCB 82 ; 32 44 2000 <-------- here
FCB 102 ; 40 52 2400
FCB 113 ; 44 60 2800
FCB 123 ; 48 68 3200
FCB 123 ; 48 76 3600
FCB 123 ; 48 84 4000
FCB 123 ; 48 92 4400
FCB 120 ; 47 100 4800
I'll not make you look it up.
Old Nov 24, 2004 | 06:40 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is an error in the hac. The TCC tables are 12 lines each. One thing you can do is to count up the addresses until the next listed address. There are a couple of others like that too.
RBob.
Old Nov 24, 2004 | 11:12 AM
JP86SS's Avatar
I've noticed alot of line number errors and such in there, the issue is that I DO have a 13th position value.
The items after that section seem to line up but I haven't nailed down if the data references in my disassembly point to the correct usage locations. That is next on the list.
I'm getting almost wrapped up with fully commenting the calibration section but this one has me worried.
I'm going to add the duplicate point to my table and continue. I'll find out if the address shift is causing other issues as I get into the meat of the code.
If anyone else has been through this and can shed some light, the help would probably save a few more hours or days to completion.
I'll post the full hac on Craig's site when done. I haven't seen a full AUJP anywhere so it would be good for everyone to have as a ref. (hopefully with no errors)
I'm leaving the values in hex so it can be followed by anyones disassembly and making decimal references to the table values.
Makes it much easier to read that way when looking your own code.
I'll put up the calibration section first then continue with the rest so if anyone else is doing it they can have a better reference to $8D. I included the "missing" table F2A.src as well. The ANHT hac does have alot of errors in there, but it is understandable. There is alot in there to deal with.
Jp
69GTOby
Apr 18, 2016 02:34 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
Amillionoh7
Sep 5, 2015 11:44 PM
greenyone
Sep 2, 2015 03:39 PM
