New to Winaldl, have a few questions
Old Nov 25, 2004 | 10:06 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I have finally got Winaldl working, and of course it is all new to me. But i only have a few questions, when you click on the tab to data log, what that does is saves all the info will your logging right? but i cant find out how to recall that info. Also what is BLM and INT?
Old Nov 25, 2004 | 10:29 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
It will save the log as a text (txt) file. Search for a file ending in txt on the date you logged the data. Mine usually wind up back in my WinALDL folder.
For data analysis, I open the text files using MS Excel. Be sure to change the files of type to "text files" in the "open file" window. The file needs to be opened as a "Tab delimted file". Or you can open the file using notebook, but it is usually too large. Excel works fine and I'm able to graph and analyze the data easily as I use Excel often at work.
BLM is a value indicating if the computer is adding fuel to or taking fuel away from the motor.
A search and subsequent reading will set you right and answer all your questions.
S-D
Also, once you have clicked the "datalog" tab you will need to click the "Start" button. Then click "stop" when you are finished.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
