idle speed adder Park/Nuetral???
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
What does this constant actually do? Does changing it really add RPMs to a (6E bin) park idle. Didn't think these ECM were smart enough to do that in 1989.
There is a switch on the auto shifter assembly. That give the P/N signal to the ecm. That's how the ecm can sense park/neutral. When you put the car in neutral or park, the ecm will raise idle speed a small amount. FYI, there is also the neutal safety switch in the same area that prevents the engine from starting while in gear(not connected to the ecm).
sailtexas186548
Aug 24, 2015 10:11 PM
