ESC Attack rate/ESC Recovery Rate???
Old Dec 6, 2004 | 11:22 AM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
What do these Tables do?
Old Dec 6, 2004 | 12:22 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Control how fast spark is retarded when detonation is detected and how quickly it is restored when the knocking quits.
Old Dec 6, 2004 | 01:59 PM
Car: 1987 Iroc-z
Cool thanks... I see your a Superram guy as well, any tricks to attaining a smooth idle?
Old Dec 7, 2004 | 12:55 PM
vernw's Avatar
WIth my cam (218I , 224E duration @ 050 and 525I, 502E lift @ 050 - 1.6 rockers on I, 1.5 on E) I get some lope. Fluctuationg 50 -75RPM. But I'm also showing the right bank is running too rich for some reason on my WB O2 sensor. Will be checking the sensor is okay next week w/a buddy, and if it's correct then I'll be swapping injectors (a real pain with a SR). That may smooth it out some, my cam is not that radical and shows 45 or so kpa vac in my data logs, but it's pretty smooth and may not see any improvement.
What are you running?
L98GTA87
Oct 19, 2015 10:43 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
RGB2015
Sep 20, 2015 09:26 PM
RyanJB
Sep 2, 2015 01:27 PM
