Stall Saver $6E
Old Dec 16, 2004 | 06:21 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Stall Saver $6E
Running $6E, After reading another post, it sounds like if I reduce RPM in my Stall Savers the car is less likely to stall. I have stalling problems/low rpm issues when shifting in and out of gear. Will changing the stall saver help me? It would make sense to raise the idle point but the other post said they found out that it was backwards. Any insight?
Old Dec 17, 2004 | 09:25 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Stall saver just puts spark control to the ignition module and your base timing is used. The real fix is to prevent the RPMs from going that low by using proper fuel mixture, spark, and IAC (idle air control stepper motor) position.
Old Dec 19, 2004 | 08:50 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I solved my stalling problem on my MAFed 395 cu in engine by getting the IAC steps at idle down very low, like about 10 counts. I would recommend that you do the minimum air procedure and set the RPM without IAC control to 100 RPM below what you want the engine to idle at.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
